I ran a search on this topic and found some stuff, but the threads I read didn't quite answer my question completely. I was wondering if you can re-use the inner pinion bearing after pulling it off (changing gears)? I know the bearing has to be pressed off and I was under the impression that this would put too much stress on the bearing to put it back in. Also is it recommended to replace the outer pinion bearing as well? Any opinions? Thanks
