1 - 11 of 11 Posts
2WD to 4WD Conversions
http://www.pirate4x4.com/forum/showthread.php?t=622105
Alternator upgrades
GM alternator install
http://www.pirate4x4.com/forum/showpost.php?p=8141279&postcount=171
Air Bag removal
http://www.pirate4x4.com/forum/showthread.php?t=627550
Air Bumps
http://www.pirate4x4.com/forum/showthread.php?t=614625
http://www.pirate4x4.com/forum/showthread.php?t=629100&highlight=air+bumps No Mounting upside down
Bed Bobbing
http://www.pirate4x4.com/forum/showthread.php?t=522573&highlight=bed+bob
Brake upgrade information
http://home.4x4wire.com/erik/4runner/brakes/
http://www.pirate4x4.com/tech/billavista/Brakes/
Rear disc conversion
http://www.pirate4x4.com/forum/showthread.php?t=610852
Fittings
10mm x 1.00
Tubing
3/16 steel brake tubing.
Clocking Rings
Budbuilt http://www.pirate4x4.com/forum/showthread.php?t=720499
Differentials
Non-trd
In the past this diff has also been mistakenly called an 8.4" or 8.25" diff. The ring gear actually measures 8", but it is not compatible with the older 8" diffs at all. The extra strength of this diff comes from the bearing cap/truss and large diameter pinion gear shaft.
Doublers 95.5-2004 Tacoma's
Trd (elocker)
A factory option on 3rd Gen. 4Runners, Tacoma 4x4's, and Tacoma PreRunner 4x2's is an electric locking rear differential. This diff is a 4-pinon design based on the Turbo/V6 8" diff and uses the same gear sets.
These locking diffs can be retrofitted into 8" diff axles if the axle housing is modified . It cannot be easily retrofitted into a T100/Tundra or open-diff Tacoma style axle housing because the mounting bolt pattern is smaller. It "could" be done by an axle builder by doing major work to the mounting flange, but that is not really a practical option.
Fitting inside older non-tacoma 8" axles http://www.4x4wire.com/toyota/tech/electric_locker/
Gray Wire mod
95-04 http://www.4x4wire.com/toyota/minutemods/greywire_mod/
05+ http://www.ttora.com/forum/showthread.php?t=67255&highlight=05+grey+wire
Doublers
http://www.inchwormgear.com/store/product_info.php?cPath=21_38&products_id=71
http://www.marlincrawler.com/htm/transfercase/taco_box.htm
Install write up for a Marlin crawler
http://4wdtoyota.com/technical-articles/marlin-crawler-install
Doubler for 2005+ automatics
http://www.pirate4x4.com/forum/showthread.php?t=602366 Not listed on Marlin's website will have to call.
Engines
3.4
Iron block w/aluminuam heads
Full Floater
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?cPath=28&products_id=94&osCsid=46673f8f71409e005d54cf9021ef99f8
Install http://www.pirate4x4.com/forum/showthread.php?t=636811
Hysteer arms Not a complete list
4x4labs
Allprooffroad
Marlin Crawlers
Trail-gear
Longfield turning radius
old 30 spline 38 degrees
new 30 spline 40-41 degrees
http://www.pirate4x4.com/forum/showthread.php?t=666554
Post SAS Cross member
http://www.pirate4x4.com/forum/showthread.php?t=600911
On board air OBA
http://webilt.com/forum3/viewtopic.php?t=1045
Rear axles
Boring dana 60 for 35 spline http://www.pirate4x4.com/forum/showpost.php?p=11197704&postcount=86
Service Manuals 1985-2006
http://www.ncttora.com/fsm/index.html
Sight tubes
Crawler box http://www.pirate4x4.com/forum/showthread.php?t=723828
Transfer Case http://www.pirate4x4.com/forum/showthread.php?t=724453
Speedo fix on 3rd gen 4runners.
http://www.pirate4x4.com/forum/showthread.php?t=626684&highlight=remove+abs
http://www.pirate4x4.com/forum/showthread.php?t=635082
3rd Gen 4Runner, fixing the 4wd function after a SAS
http://www.pirate4x4.com/forum/showthread.php?t=635086
Steering pump upgrades
TC pump install
http://www.pirate4x4.com/forum/showthread.php?p=8613844#post8613844
Steering shaft
http://www.pirate4x4.com/forum/showpost.php?p=6901399&postcount=4
http://www.pirate4x4.com/forum/showpost.php?p=2212900&postcount=7
http://www.pirate4x4.com/forum/showpost.php?p=7524841&postcount=12
Steering wheel spiral cable/clock spring tech
http://www.pirate4x4.com/forum/showthread.php?t=697181
Tire Carriers
http://www.pirate4x4.com/forum/showthread.php?t=731499
Transmission and Transfer case models for the 95-04 models
W59 = 5sp for 4cyl (2wd and 4wd)
R150 = 5sp for V6 (2wd mini)
R150F = 5sp for V6 (prerunner and 4wd)
A340E = Auto for V6 (prerunner)
A340F = Auto for 4cyl/V6 (4wd)
A44D = Auto for V6 (2wd mini)
output shaft for the auto between the A340E and A340F is different. So you cant just bolt a transfer case up to a A340E from a A340F
Transfer case clocking w/o doubler
http://www.budbuilt.com/new/tacoma.html
Transfer case input shaft
http://www.pirate4x4.com/forum/showthread.php?t=592937
Left Gear Drop transfer case option.
http://www.pirate4x4.com/forum/showthread.php?t=536994
http://www.inchwormgear.com/store/product_info.php?products_id=985
Right Gear drop transfer case adapter
http://www.pirate4x4.com/forum/showthread.php?t=617536
Wheel bearing replacement
http://www.4x4wire.com/toyota/maintenance/rear_axle/wheel_bearing/
Weight of items
Manaul hub system
Lower control arm 23lbs
CV 19.5lbs
spindle w/upper arm 35lbs
hub (no cap) 2lbs
cv stub 5.5lbs
Standard Items
OME 882 coils w/firm shock 22lbs
Vented brake rotor 12.5lbs
Builds ( good reading before thinking about swapping)
Infernal Jeep Build http://www.pirate4x4.com/forum/showthread.php?t=626083
Booger Weldz 2002 taco build http://www.pirate4x4.com/forum/showthread.php?t=616611
ErikB 97 4runner http://www.pirate4x4.com/forum/showthread.php?t=609488
lbz134 97 Tacoma SAS Build http://www.pirate4x4.com/forum/showthread.php?t=599578
CAPS 97 Tacoma SAS build http://www.pirate4x4.com/forum/showthread.php?t=485795
Revivalist 03 PreRunner --> 4x4 SAS http://www.pirate4x4.com/forum/showthread.php?t=504902
TacomaJoe95 95.5 Tacoma http://www.pirate4x4.com/forum/showthread.php?t=500188
Ballastic Fab Shop 95.5 Tacoma http://www.pirate4x4.com/forum/showthread.php?t=558164
Thanks for volunteering! Just edit all the links and info into your original post and then ask a mod to sticky it. Then keep updating periodically it as needed. :D
Ok well if anyone can think of some good links to add or sections post up. Later on I will have the mod delete the post after I add the stuff. No bitching about what companies are added. Don't care if you hate one company if they offer the product let the reader decide which company to go with.
It'd be nice to know what 3rd fits in a 96+ 4runner. Is it a traditional 8" or a taco 3rd?
Banned
Pirate4x4 com Tacoma Forum FAQ
I have been doing some research on doing a SAS on my tacoma for some trail riding i wanna run 35s. but havent seemed to find the info of what i need. Any help/ feedback would be much appreciated
thanks
The non-trd Tacoma rear end is not an 8" at all. Or at least mine wasn't NOTHING measured up the same. It is like everything is sized up. The ring gear, carrier etc. are a larger diameter in addition to the bearing cap trusses. The bolt pattern of the third member is even larger as are the bolts for it. The only things that match up are the splines still being 30 spline, and the pinion flange. I don't know where the 8.4" thing came from, but the OD of my non-trd Tacoma ring gear was 8.875" if I remember correctly.
I got a bit familiar with this as I wanted a locker for my 4cyl long before aftermarket options were an option, so I bought a trd housing and 3rd, and fitted it up to my stock axles and brakes. It's not as simple as it sounds, but nothing ever is. But I got a pretty durn good side by side comparison.
Great collection of information! :)
need help wit my taco
just pickup a 2003 taco wit 6" lift the guy i got it from told me that i need to lower the drive shft center bearing i got sum ideas to do it just wanted to get diffrent views on how to do this. any one with pic of there truck and how thay did theres would be helpful thanks
So this could use a boat load more info...
But I am a mere taco newb.
The bible helps a first gen builder immensely, this not so much.
1 - 11 of 11 Posts
