1 - 5 of 5 Posts
Well I've been building up my jeep pretty well over the summer/winter but a new pitman arm is getting me stumped. I have 1 ton TRE's and I can't drill out the stock one otherwise there will be way too little metal around the hole, I am sure the end of the arm would sheer right off. So what I need is a totally flat pitman arm that is right around 6" long, that can be drilled or already is drilled for 1 ton tre's. This is on a saginaw box. Closest I have come across is early 90's ford but the key ways are off by 45 degrees. SO does anyone else have a place for me too look or dare I say it get a custom?? Thanks
Take a triangle file and file the keys so you can reindex the pitman arm to fit your application. I did that on my pitman arm to center it to the steering box. Works great.
Try a Camaro pitman arm. Long, flat, beefy. (I forgot which years)
1 - 5 of 5 Posts
