Modified Pitman Arm
We start with a new stock IFS style pitman arm and remove the ball joint. A tapered sleeve is welded in place for use with FJ-80 tie rod ends. Unpainted finish. $99
Fabricated Pitman Arm
This pitman arm is designed for crossover steering systems with spherical rod ends. Bolts to IFS steering box sector shaft. Unpainted finish. $149
what don't you people understand about a dropped arm. Not a stock arm with a hole drilled in it .
Love this, he asks a stupid question then he gets RUDE, DO A SEARCH!!!!
already did a seach and made phone calls no body makes one .I was wondering if anything is interchangable or what has worked for fabrication... Please if you don't understand the question don't reply.
Pretty simple to just go buy one. If you can't figure this out why are you biulding a rig. You WILL run into alot of situations like huh (how di I change this u-joint ) Just agravatin ya TNTOY. This is a silly post that should have been asked on the playschool web site:flipoff2:
