1 - 20 of 753 Posts
not sure what to really call this yet but plan b seems fitting for the moment
with knowing how long its going to build my buggy right the first time I knew I wouldn't be wheeling this year and it was starting to get to me. sure its fun to go out and ride bitch but its never the same so been looking for a cheap ride to hold me over. found this gem as price was right and it drove on the trailer no problem
1993 F250 with a 351 and c6. thing is beat and needs some love but price was right as motor sounds good and that's all im really after. with this build I know I want a full cab with glass and doors as want to winter wheel it. will ditch the box and cut the frame right down get a sub 120 wheel base. 3link front with air shocks and rear will be leaf sprung, lots of cutting and my 44s then party time.
will be budget rig and hope for a fast build as want to wheel this this summer and winter as I build the buggy so I can take my time and build it right
now pics
and hope to look something like this when im done
got the truck in the shop, box off and frame striped today
found this and some other ghetto fixes on the truck
rear bumper with bumpers that was welded to the frame
this week I plan on getting the rear diff striped of all the crap and ready to go back in, also make up my wind on what I want for wheel base so can cut the frame down
got the rear diff stripped tonight
also cut the frame down, took 20 inches out. wasn't able to do a Z cut this time but once fully welded and with a small fish plate I don't see it being an issue
frame scrap and my NV271 tcase I plan on swapping in as well
nice :grinpimp:
Looking forward to watching this.
What're your plans for the leaf rear? Simple shackle flip and traction bar?
Discussion Starter · #10 ·
was thinking of just putting them under the frame but worried will give me to much lift. so yes plan is just do a shackle flip in the back with stock brackets and i have a set of belltech shackles from when i lowered my F150. have a traction bar left over from the truggy build so can use it if its needed
You never mentioned which front axle? I assume dana 60,but what year? A super dirty axle would be tits for strength and cheap (at least around me )
Looks good so far, i think the frame is going to be fine with fish plates. You cutting anything out of the rear to help departure angle?
Discussion Starter · #12 ·
going to use my 79 HP60 with 4.10 and chromos with high steer and full hydro.
was looking at the back of the frame tonight an only think i can cut a few inches off as was thinking of just putting the rear tank back in the stock spot. makes life easy for mounting it and doesnt hang down but wont let me cut the frame flush with the rear leaf hangers.
Discussion Starter · #16 ·
Well that axle will do the trick.
Good plan on the stock mounted tank in the rear, that would trump cutting the rear out just for ease of install and building it quickly. Looking forward to the finished product.
Discussion Starter · #19 · (Edited)
tonight was just one of them nights where nothing worked in my favor and got nothing really done. was short some hardware for putting the spring hangers back on, found a hole in the rear fuel tank so have to buy a new one, and couldn't get the left springs bushings out. so will try again tomorrow and hope for some better luck.
pic of the fish plate and front spring hanger on even if missing 2 bolts per side
rear is new stock hangers just flipped and using some belltech shackles I had from when I lowered my F150. can also see how much frame is past the hanger and rear crossmember so not much to gain from cutting it off
got one spring pack torn down and painted but will need to replace the bushings
I would have moved the springs under the frame for simplicity and added flex. Stability can be argued here...yes. Sure it will be fine though.
1 - 20 of 753 Posts
