Like LUVMYTJ said, we did this swap a few weeks ago on my '02 Wrangler. When I first drove it after the swap, I got DW at 45 mph, that was extremely violent and would not stop until the rig had come to a complete stand still. When setting up the front axle, the angle finder on the lower, or upper ball joint, my caster was 5.5 to 6 degrees, even after we had it installed. One of our wheelin buddies owns a front end shop, so i took it too him. His machine said I had 2 degrees caster. He adjusted out my lowers, as far as they would go, sucked in the uppers and installed 1 degree ball joint shims to get me to 4.5 degrees caster. All was well, until I tried a fast drive on a stretch of interstate and the DW reappeared. I decided that I'd go over the front end with a fine tooth comb and I tightened every nut and bolt. I found that both the upper and lower track bar bolts could use some wrenching. I put a breakover bar on both, but I really torqued down on the upper bolt. I haven't had a single bit of DW since doing this. I do get a bit of shimmy, now and then, when driving fast over a whoopty-doo, like when going over a bump and the front end gets light. That's when I get a bit of shimmy. Currently, I'm not running any steering stabilizer and have just a noticable bit of bump steer, but it's nothing that I worry about. My advice is adjust in as much caster, as possible, in the 4-6 degree range and make sure all your nuts and bolts are TIGHT, especially the track bar. Good Luck.
