1 - 1 of 1 Posts
Ill try to give a little more info this time.
I have a 87 yj. I have installed a ford explorer 8.8 with discs.
Wasn't able to get a brake pedal. Then I removed the o-ring from inside the prop valve. Still no brake pedal. Can I remove the shaft from inside the prop valve????
Should I remove the prop valve???
If I do will I need a manual adjuster?????
Or should I completely remove my booster and master and install an aftermarket master ( Mopar performance has one with a built in prop valve)
Any help would be great.
1 - 1 of 1 Posts
