1 - 3 of 3 Posts
Sure...Just keep in mind that you should "shoot" for a -10 port on the return at the pump...All the way down.
Talking in lenght with Jeff Howe, the most common problem with full hydro systems is starvation at the pump. Hence -10AN lines and fittings FROM the res. to the pump (and the return port on the pump). -8AN from the orbital to the res. and -6AN everywhere else...Station will/can confirm as well.
1 - 3 of 3 Posts
