portioning valve and booster ? Revised
Ok, so I have to revise my first part. I have a 90 XJ limited with ABS. I am not going to be using the abs lines anymore. I also have a cannister or ball instead of a brake booster. So has anybody done a switch on a set up like this. My main questions are do I need to remove that cannister, will the E-350 MC match up to this cannister? Or should I go with a summit proportioning valve to a e-350mc to a 96 xj booster in to my lines set up. Well thanks ahead for any help and if you have any pics please post or send to [email protected]. Oh yeah and I am not sure if it matters but I am running dual piston calipers upfront. thanks again.
I am putting in a 14 bolt in the rear of my Geep and I know I need a new portioning valve for the disk break set up. Anybody have any info on what they have used I went with the front calipers off of a chevy instead of the el dorado. Also what type of booster set up does a 90 limited come with. i have a cannister were my booster should be, so I was wondering if anybody has any info on that too. thanks
