1 - 20 of 46 Posts
Slowly gathering parts for a 2wd 3 gen build. This will be a pretty mild build compared to my last few trucks but it will be different than most. I know it will most likely turn into a huge flame fest. Does anybody even care if I do a build thread? I know Stubbs is getting bored with the site. If nobody cares I'll kindly fuck off. :flipoff2:
My last few trucks were the typical IFS conversions. I never liked the way that the trucks always sat so high with the shitty frame and drop hangers. I always said to myself the next truck I build will be a 2wd. I wanted to have the truck sit as low as possible so I decided spring under was the way to go. After a few minutes of fuckery I ended up with this.
I haven't touched the front axle in a few months. It's been way too cold in the garage to do anything. I did manage to get it partially sand blasted at my friends. I need to pick up a couple more bags of blasting media to finish it.
Since I planned on building it low hi steer was out of the question. I decided to go the cheap route and reuse what I had. I ended up picking up another set of stock steering arms from Gslander. I had the arms bored out to 3/4" so I can run a grade 8 bolt thru for double sheer.
· Premium Member
If I'm wasting bandwidth let me know. I'll delete this shit!
unpossible!
even a "mild" build thread with good pictures is better than a "hardcore" tech question that is vague as fuck with no direction :flipoff2:
fabbin' is fabbin'
One issue I ran into doing drop/lowered perches was the spring pin hight. It would hit the axle tube when it sat down on the perch
Discussion Starter · #10 ·
unpossible!
fabbin' is fabbin'
That's what I figure. There isn't much of anything going on these days. :(
Thanks for the heads up.
· Premium Member
meh, there is still 'lots' going on in here, just not like it was during the peak of pre-facebook pre-great recession.
not sure how many other folks log on daily, but over the course of a week it seems pretty solid. there is so many options and so much of the basic stuff has been hashed out that flaming in build threads isn't really much needed. i'd prefer more of a build it and see anyways...best way to find out what works
Discussion Starter · #12 · (Edited)
Now that I know at least a couple people are in for the flame fest I'll post more. I hate cleaning Toyota front axles with a passion. This thing was a fucking mess. After lots of elbow grease and brake cleaner blackout fests it started to look better. A quick trip in the blast cabinet and some primer/paint it was done.
Im cheap so I am reusing the solid rotors. Hubs got new wheel studs. Tires are going to be a skinny 33 so I think I'll be fine. If you think I'll kill a busload of nuns I'll up my insurance. It's cheaper than new rotors and calipers. Fastest I drive in this truck is 45. The 4 speed doesn't like 55.
· Premium Member
new rotors are $7-15 each on rock auto, might as well at least replace them :flipoff2: with new rotors and pads, they should last much longer than running new pads on old rotors.
· Premium Member
Keep the pics coming, i would much rather read stuff like this than some ultra 4 car built out of unobtanium! Ive been wondering what you were doing with the arms!
· Premium Member
This
If this guy is telling you are being cheap, then you know you are being way too big of a cheap ass!!
This
:laughing::laughing:
16.15 each for fj vented rotors on rock auto. Iirc you can reuse your 2wd calipers on them too. Talk about a cheap!
· Premium Member
Sub'd. I'm on here everyday, two or three times at a minimum. Yeah, I know. I need to find something else to do.:flipoff2: Anyway, always interested in learning/seeing different ideas, variations, and general wtf everybody else is doing. Keep it coming.
Edit: +1 for shackle reversal. :flipoff2:
1 - 20 of 46 Posts
