1 - 19 of 19 Posts
So I bought a CMMG Ar-15 today, and the guy I bought it from says it is chambered in 5.56/.223. I've looked all over this thing for a stamping, all over the barrel, and the upper in general. The lower is stamped 5.56/.223 but that doesn't matter. What's the easiest way to tell short of having to buy something? If that's what has to happen I'll just shoot .223 out of it.
Pull the hand guards and see if it has any barrel stampings. The actual upper doesn't care. it is the barrel and extension that should be marked
Is there a twist rate ie 1/7 or 1/9 also look for a NATO stamp on the barrel
If its 1:7 then it should be fine with 5.56 don't quote me on it though. Also run a rod with a brush down the barrel with marks so you can measure when it makes 1 full turn then measure how far it traveled in that one full turn
After reading there, and a couple other sites, looks like I just have an unmarked one. Possibly a blem or something..
No big deal, but it would be nice to know if I could run surplus ammo through it..
Good call, I'll do that in the am.
Go here and decide what profile barrel you have.
http://www.cmmginc.com/Articles.asp?ID=266
Then look around and find a CMMG rifle chambered in only .223.
Rifles
Then go to their barrels and find one in .223.
Barrels
If all else fails, call them with the serial # and ask them.
One way or another, the barrel is stamped.
3d Artist for Hire!
Barrel twist is in no way connected to the chambering.
It *should* be marked on the barrel. Usually top or side, just in front of the front sight. Sometimes it'll be marked and covered by the handguards, all as mentioned above.
If all else fails, take a mic to the bore at the muzzle and measure it. That'll give you at least caliber.
Easiest way would be to take to a gunsmith and have them check. Shouldn't cost much (if anything) for the 10 seconds of work they need to check it...
Discussion Starter · #11 ·
Rifles
Barrels
Hell after looking around there, it doesn't even look like they sell one in .223.
It's not marked at all on the barrel. Not under the handguards, not anywhere. Only a G under the handguards, on the bottom of the barrel.
I guess I'll just call them and ask. Just figured there was an easy way to look and see.
Discussion Starter · #13 ·
Yeah, seems to be relatively common. Oh well. I'll just call them Monday and see what they have to say. I'd say it's 5.56 considering they don't list a .223 chamber on their site, but I'd rather ask to make sure.
Green bastard
So to add onto this, what if its a 5.56 and you shoot 223 and the other way round?
5.56 will shoot 223 but 5.56 has a higher pressure then 223 so you can figure out what could happen
3d Artist for Hire!
One way will cause your rifle to explode in an apocalyptic firey inferno destroying the entire universe. The other will get you laffed at by your local "tacticool" crowd because you're not shooting mil-spec, and thus, not qualified to be on the range.
I doubt you will find a non-match barrel AR built in the last 20 years that won't shoot 5.56 anywhere...
1 - 19 of 19 Posts
