1 - 3 of 3 Posts
Tracker Powersteering setup. I adapted the 1.3L bracket to the 1.6L for the pump, but you can just swap the pump mounting bracket. Comes with pump, pump bracket, gearbox, high pressure line, tracker pitman arm, Samurai tie rod end with weld in bung, and tracker box adapter plate. The steering box also has the rag-joint eliminator. This came from the same tracker I pulled the 1.6L from. All parts are in good working order with no mechanical issue. You'll need a reservoir and and some hose to run the feed and return lines, but everything else bolts right up. I'm selling this because the diesel swap i did forced me to go Toyota IFS box on the outside of the frame rail. I'm asking $200 obo for the whole setup.
1 - 3 of 3 Posts
