1 - 4 of 4 Posts
I just spent an hour searching, and cant find any information on my problem so here it goes.
I have a 91 chevy 1500 with a 60 front, high crossover steering, and using the stock IFS steering box (3 bolt).
I have never been able to turn well, so I started looking into the problem. I put the front axle on jackstands and cranked the wheel lock to lock both directions. From center its 2.75 turns each way to lock but the tires do not turn until they hit the steering stops. Nothing is binding or hitting anything else. It looks like the tires only turn 60% of how far they could if they went to the steering stops. I have been wheeling it for years and everything works fine except that I can't turn sharply.
I just got my hydro assist parts and I am pulling the box to tap it and the pump to upgrade it but I want to fix the turning problem first.
The pitman arm is 7" center to center, which seems standard. I am running the sky dana 60 high steer arms.
My drag link was angled up a bit, but I am rotating the box down a bit so that it will be parallel with the axle and tie rod while I am at it but I am positive that wont get me to hitting steering stops.
So is the problem my box? do I need a longer pitman arm? Something else?
It sounds like the geometry used with the original box and steering required less travel. It may have even intentionally had less wheel travel as not to over-extend the axle joints due to IFS or other reasons. What that means is the piston stroke in the box is too short to meet the full throw of your new 60 and the style of steering geometry it uses. A longer pitman arm may give you the added throw you need, but it will put more torque on the sector shaft. I'm not familiar with the box, but there could possibly be some internal stops that can be removed or relieved to give it more piston throw, thus more sector shaft rotation. I would not add the ram until I had a box that would travel to the wheel stops. The ram will continue to try and push the steering even after the box has two-blocked, putting a lot of stress on the rod ends. If you can't get a longer stroke, shorten up the wheel stops.
1 - 4 of 4 Posts
