Set Up: D44 with Saginaw Pump (Delphi), 36 sx's, toyota IFS box on an early bronco. Weight is normal for an EB with 8000# winch. The pump squeels whenever under pressure with the tires aired down. If I air down below 6#'s it gets really bad. I want to go to 35 16 15 boggers for the snow and rock, but am thinking the problem will get much worse with that much tire surface on the ground.
It seems that others on the trail are not having the same squeel as me with comperable set ups. It seems I shouldn't have to add an assist even though I know that will resolve the problem. Thoughts suggestions.
