I bought a radius roof rolling chassis from a fabber here in AZ. Its a big car that will seat 5 people but probably will only carry my wife and daughter and most of the time only me and my daughter and some friends.
This may be a slow build as it has already taken me 2 years. I would like to drive it at the dunes in November and eventually in a year or so down to the baja peninsula to pre-run.
Its made of 1.5" x .125" wall DOM. The trailing arms and A-arms are made of 1.5 x .125" chromoly tubing made by Fodrill Motorsports. It has 2 piston Tatum Motorsports wide 5 front brakes on 2" hollow chromoly spindles made by Fodrill Motorsports. The rear brakes are Tatum as well but are 6 piston 934 Midboard brakes. The axles are from Gear One and are 32" long 35 splined. Transmission is from Fortin and is a standard 4H pattern with internal oil pump. Ring is 4.38 and is rated at 850hp. I currently have a Northstar v-8 motor attached to it that produces 400hp. There is a 23 gallon fuel cell and oversize radiator with dual 16" fans. Coil carriers and triple by-passes are Kings. The rear coil carriers are 2.5" body with 16" stroke and the by-passes are the same but 3" body. The front has 2.5" bodies 12" stroke with piggy back reservoirs. I have plans to by double by-passes for the front. Steering is a GEAR ONE SUPER RACK- # G1-3009 with a Char-lynn torque generator attached to a 3 spoke steering wheel. Autometer gauges complete with Tach, oil press, water temp and fuel. Lowrance GPS and Rugged headsets that are car to car as well as person to person inside the vehicle. You can also listen to music with an attachment on the unit of an Ipod. Jamar shifter, cnc turning brake and Triple X seats with Mastercraft 5 point with sternum straps. RObby Gordon 17" bead lock wheels with 35" ProComp M/T's.
It needs a few more items but mostly wiring and then it can be driven. Paint and body panels come after I get all the bugs worked out.
I will keep up on the updates as I progress.
