1 - 4 of 4 Posts
I bought a 1990 Toyota 4-door runner,, and it came with a used Pro-Comp 4" lift,, and all the parts are there ,except the front spindle cone spacers, which go into the stock Toyota spindle to eliminate the taper, for a 5/8" bolt to be installed,,, I had a local shop inquire ,,and they advised that I would need to buy a complete boxed item (which includes the spindle cone spacers)but has a bunch of other parts I already have, and costs about $75.00,,, anyone out there have a set of these ,they might not be needing?? or know where I could get just the 2 small pieces ??
FWIW, I put a TM kit on Edge's rig w/o those pieces w/ no problems. It was a used kit and they were stuck (rusted?) in the old knuckles and I couldn't get them out. As long as the bolt is tight, there should be no play anyway.
Also, I *might* have a pair of those that I salvaged from Edge's kit (later) by using a jig saw and cutting a slot in them to get them out. So now instead of a perfect circle, they look more like the cone washer on a hub...
I'm not sure if I even have them any more or if I can find them since we moved, but I'll look if you want me to. Let me know.
If I'm thinking of the right parts, I got some replacements localy for $15 or so and never used them on my TM kit either. PM me with some more details and you can have mine if I can find them. Or like Eric said, you may not need them.
Erik,, yea if you could check to see if you still have them laying around I would appreciate it, <IMG SRC="smilies/smile.gif" border="0"> .
Bones,, I PMed you,,
thanks to you both,,!!
1 - 4 of 4 Posts
