1 - 14 of 14 Posts
My fuel pump whines really loud at all times when the engine is running, is this a sign that it could be going out? Is there anyway to quiet the noise? Thanks, Brody
Is this the Holley system? If so, I know somebody else with that problem.
I might also ask if it is an in-line fuel pump (not an in-tank unit)? An in-line pump *may* make an awful amount of racket, especially if it is more than 18" away from the tank and not below the lowest point on the tank (this is the case with my rig, as well as others who have mounted an in-line pump quite aways from the tank...though not everybody experiences this...). Air in the line also creates more noise.
Loud pump
I have the Holly inline pump on my TBI. it is so loud it gave my wife a headache. I mounted it in a old radiator hose then raped it in a foam pipe rapp. It is much quiter now. I worry it will git to hot and burn out. I think I will buy a spare pump from a differnt manufacture. Glen
the two we run are nice and quiet. but we have the new style. Is yours black with holley on it, or is it silver with out any labeling. Also did the wiring harness plug in, or did you have to adapt the harness to ring terminals. Maybe they had some problems with the old pumps, and replaced them.
sounds like you might have junk in it...inspect the pump as mine runs very quiet....flush it in reverse with compressed air or pull the rear screen and inspect....also make sure it's not getting starved for fuel....
fuel pump
Depending on how you have the pump installed-try to create a "loop" in the fuel line between the tank and pump to trap gas and keep from getting an air pocket. Once I did this my pump was much quietier. Steve:rolleyes:
mine whines a little, not loud enough to hear over the motor, though. I was sure to mount it under the lowest point on the tank, and not too far away from the tank. Been going good for over a year...
I've had both old and new holley pumps, were quiet when new, but became very loud. Suspect junk getting into the pump or possibly, heat getting to it. :confused:
1 - 14 of 14 Posts
