1 - 5 of 5 Posts
Did anyone have a tough time drilling the frame for the locator pins for the MORE rear shock mounts? I have used everything large and small even Carbide bits. I just tried my pneumatic die grinder and with new bits and it won't go through the frame either. Would really appreciate any advise. Thanks.
3113701
Like mentioned above, slow speed and oil start with a smaller bit and gradually step up the size. If you have a grinder you can sharpen the drill bits. Just try to keep the angles the same as the factory angles are.
Thank you for your reply, I am going to get some cutting oil and try with a few more new bits.
1 - 5 of 5 Posts
