1 - 7 of 7 Posts
This was not my idea, I stole it from mrblaine. I want to give the credit where it is due. just wanted to show the progress. So far I love it. With this idea I am able to run RS9012X which gives me about 13" of travel. I am running these on all four corners.
how much did you sink it into the frame? how much is it sticking out? What else did you do to solidify the frame at that point?
Yes it is a f250 mount. you can get it at any ford dealer. I also used them up front. I cut out 3 sides of the frame and left the back in. You have do use your own measurement so they will fit the lenghth shocks you have. I am running RS9012X shocks all the way around. There is a cross member behind the area I mounted the rear tower.
1 - 7 of 7 Posts
