Project Adventure DirtyMax
Well I have been working on this project for about 5 weeks since the opportunity came up to go and mess around in Baja in April.
Since all of the BS about what is and isn't a Expo rig I decided to Call it a Adventure Machine :flipoff2:
Anyways What I am working with is a 2003 Chevy 2500HD Duramax w/ ZF6 Trans 4x4 Ext. cab Short bed. The truck was basically stock until over baby Jesus B-Day I did the following.
Cognito 4-6" Non Torsion Bar Drop
Cognito UCA
Bilstiens
3" block in the rear
Cognito front CV driveline
Spicer upper and lower Ball Joints
GM Pitman and Idler Assm.
Both Timken unit bearings from Dmax store
All new energy Double shoulder bushings on LCA
New Cognito UCA bushings
Both Torsion bar crossmember bushing mounts
New Cooper STT 35x12.50R17
Fuel Hostage wheels
Disclaimer: I'm not religious if you can't tell
Then this trip came up and I knew the truck was to the task but would come home beat. So I decided to do the following since I knew it was heavy and way under shocked/sprung. I don't PLAN on every catching air in this thing since it ways 6500 lbs empty. But I had to do something so it can at least try and soak up the big hits and rough roads better without beating the truck up too bad all with of the shelf parts so replacement are easy to come by and a little fab time.
Things that need to be done/bought
Suspension-
Updated Cognito NTBD brackets
Fox 2.5 remote resi Shocks
Deaver p/n G7 rear 4" Springs
New Bumps GM- 15835667
Better Rear Bumps dunno yet
2 new CV shafts
Steering-
Center link and tierods from DmaxStore
RedHead Steering gear
Other parts/things to do:
Fab a single shock hoop for the front shocks.
Finish front bumper install lights and winch
build Rear swing tire/ water can carrier/ rear bumper a Total rip off of Matt Heltons Hi 5-0 rack. Why change it's perfect in my eye's.
more HID lights
build Swing out mount for fridge in the bed
mount 2 spare yellow top Optima's where spare tire is under bed.
Better CO2 mount
Lube storage box from artec ind.
Kill switch/anti theft device. Maybe some flame throwers
battery hold downs, stock one are crap.
Mount the Lowrance GPS better
Mount for Action Packer
Wiring lots of it
Limit straps
Modify CanBack Top
Service and prep the whole truck.
I never made out a budget for this stage since there is no point of having one since I won't stick to it anyways.
I'm sure that I am missing some things. Here is how it sat in the beginning of stage 2
Cognito UCA
Bilstiens
Fuel Hostage wheels
Suspension-
2 new CV shafts
Steering-
more HID lights
Better CO2 mount
Wiring lots of it
Limit straps
Modify CanBack Top
