221 - 240 of 244 Posts
Discussion Starter #221
Did you ever change up your fan? Any overheating on the ua trip?
How is the 4.0 and 5.38s on the road?
yes fan/shroud was all changed.... no more heating issues, unless I forget to flip the fan switch :/
4.0 and 5:38s is a little deep for street driving, but I can hold 75mph without screaming the motor too bad. WOuld love to have more power for the street on big grades and climbs though. Offroad everything is fine.
go on.... :smokin:
My brother has an m90 supercharger with 90% of the parts there that he was ready to put on his 4.6L stroker motor. The stroker is now unrepairable due to already being bored .060 over and needing more, so he is going to a hemi. I think he has ~$500 invested into the setup and I'm sure I can convince him to make a deal with you if your interested. I believe you sold me an anti rock and I'd be happy to deal with you again.
Sent from my SM-G930V using Tapatalk
Discussion Starter #227
Did he gather parts himself or is it a kit of some type?
He gathered the parts himself. He's got the super charger, some various gages, and a tuner to get it running right. He was planning on running the m90 upside down where the AC compressor goes. He started fabbing the bracket up, and then he got the super charger scanned so he has a CAD drawing for a gasket.
Discussion Starter #230
After a year of having the Jeep, and shocks not being tuned... I finally made time to get some tuning done. I met up with Ryan at AccuTune and we got BajaJeep dialed in.... now I just need more power :)
Discussion Starter #232 (Edited)
Quick update since... when ever.
-Ordered and installed a badass Full Float Dynatrac XD60 with ARB locker.
-Also ordered some new Milestar Black Label 40" tires. These tires are huge!
-Swapped in new Motobilt 19gallon fuel tank.
-Added DSC adjusters to rear shocks <--AccuTune Offroad huge help with this.
-With new 40" spare on the back, had to swap rear springs to compensate for the weight which made a huge difference.
-Next up: new clutch, B&M short shift kit and MORE wheeling!
If your on Instagram, check out @bajajeep_mike
Discussion Starter #233
40" Black Labels have been awesome. I was worried about driving these on the street, but I have at least 1200 miles on them now and have been awesome. One thing thats crazy to me... I mounted them myself and didn't have them balanced. Ride down the 405 fwy at 70mph no problem! Love it. Traction has been great in sand, dirt, rocks and wet rocks. I plan to beat the living hell out of these tires and report back.
why did you walked away from a RockJock on the rear?
Discussion Starter #235 (Edited)
I was never a fan of that axle. Getting to the gears was a pain in the ass and its a semi float axle. Tubes are small, which is why it bent on the roll over. For how hard I drive... it was not going to last.
I hear ya.... wouldn't a shaved 14 bolt with factory disc brakes be a stronger/cheaper option?
Discussion Starter #237
Sure. If I wanted to be full width, low pinion and 8 lug.
Those axles suck even if you don't drive hard....good on you to walk away from that pile of shit.
The 14 bolts we shave and put on jeeps are 63.5" WMS (DRW).....not wide at all. Full float and with the pinion adjusted at the right angle and a 3/8" pinion guard, it can take an impressive beating. Aftermarket hubs allow other bolt patterns and I run alloy hubs on mine...8 lug with wilwood brakes :flipoff2:
Yep, I have the same axle under the rear of my JK and it is a POS....and worse is Curie's crappy customer service. My other rigs (including my rock buggy) have junkyard tons under them built with top-notch parts and I couldn't be happier.
Discussion Starter #240
:flipoff2: Yea you and your fancy Jenny Craig 14B hubs. Come wheel Fordyce with us this summer!
