101 - 120 of 218 Posts
Discussion Starter #101
I haven't had a lot of time to work on this thing lately. Next step is welding the axle tubes to the center section on my 14 bolt and then welding the truss on.
I was putting it off because welding to the cast center was scary and I didn't have any ni99 rods. Picking some rods up this weekend and decided I'm just gonna send it.
I have read on the webs that some 14BFF retubers on the net don’t weld the tubes to the center section due to the HAZ it creates in a critical spot. Just the rosette welds. Definitely makes since and I have seen pics of axle tubes breaking there. If the truss ties into the pinion support doesn’t seem like much advantage to me to weld the tubes. Just a thought.
Discussion Starter #103
Oh man. I'm pretty much looking for any excuse not to weld this. You're not helping :flipoff2:
Truss does tie into pinion.... hmmmmmmm... I could get a lot more done this weekend if I wasn't waiting for an axle to heat and cool....
With the truss tied into both sides and the pinion, is it really gonna go anywhere? :D
Discussion Starter #107
After much pondering, I decided that the pinion brace should be enough to stop the center from spinning. If I snap 3 5/8 grade 8 bolts, then I'll revisit the issue.
Got the truss welded on
Then I went to position the axle under the jeep. It turned into more of a shitshow than it needed to be because I lacked vision when I pulled the jeep out and set it on some jack stands. I don't have any wheel dollies, so... I'll let the picture speak for itself. I can't tell if I'm stupid or clever. :rolleyes:
After a bit of jimmy jacking around, I got everything where it needed to be. Axle is now lined up where I want it, jeep is jacked up to where I want ride height to be. It's all(mostly) center.
I was gunning for 7 inches of up travel, but was a little worried about how tall the truss and upper link bracket was. It'll barely fit. We'll see how that goes.
Then I started cleaning up the spots on the frame where the brackets go. First thing that had to go were the old leaf hangers.
Upon closer inspection, it appears I'm not the only hack who has worked on this thing :laughing: More lines on the To-Do List.
Next up is clean up the rest of the frame and tack up my link brackets where they need to go. I'm a government employee and it's Martin Luther King Jr. day, so I have a dream of getting everything under there today. Fingers crossed. :D
Discussion Starter #108
Hackery cleaned up. Also got all my frame brackets tacked in place, but by the time I remembered to take a picture it was dark and cold, so instead, I compromised and stayed inside and drank beer.
Nicely done.
BTW, for just rust/paint/contaminant/mill-scale cleanup, these things:
https://www.harborfreight.com/4-1-2-half-inch-nylon-abrasive-wheel-94017.html
Are pure joy. Removes paint/rust FAST and doesn't eat into the actual metal like the flap disks do. Probably wouldn't help much here, but I'm sure there are other areas you'll have to clean prior to welding.
I'm perusing my subscribed threads. Glad to see this pop up. Nice progress. Looks like you can section a portion or relocate the rear crossmember to gain some more vertical clearance between the truss and floorboard.
I didn't know you had a two car garage. Makes life a lot easier.
Does your crossmember limit uptravel? Mine did so I cut it out and used a piece of 1-1/2” tube.
Discussion Starter #112
There's a chance I'll have to do that. Just eyeballing it, I should just barely clear, but we'll see once the links are on and I start cycling things.
Discussion Starter #113
Two car garage, but it's got too much kid toys/mountain bikes/surfboards/camping gear/dirt bikes/skis/snowboards in it to be useful.
I think I need to chill out on the hobbies. :rolleyes:
Discussion Starter #116
Not much progress lately. Got sick for a week, went to KOH for few days, back at work now... but in the meantime, some 14" coilovers from Accutune showed up.
Props to Ryan over there. He makes it really easy to figure out spring rate and valving and definitely knows what he's talking about.
Discussion Starter #117
Got lower link mounts cut and tacket on my axle. Don't make fun of where I tacked it, I was too lazy to wire all the paint off, so I had limited places that were already bare metal to choose from:
After that, I decided I should mockup my links first. I'm not sure if I have stated this before, but uh, I have no idea what I'm doing, so I figured it's better if I do a little recon with PVC before cutting up my steel tubing. I affixed my heims with the finest painters tape I could find and checked to make sure I actually knew how to use a measuring tape.
Everything lined up and the axle ended up exactly where I wanted with no drama.
After that I cut my actual metal links to the same length and was getting ready to prep them for welding when the power went out. It has been windy here and I live in a town with super old power infrastructure, so this happens occasionally. After the third time in an hour, I got pissed and went inside for beer instead.
I have a buddy who has offered to tig the bungs into my links. I'm considering taking him up on that since I've never done this before and his work looks super pretty.
Take him up on the TIG. I paid my buddy's kids to do some work on my old YJ and I came back to find it all TIG welded. Fanciest thing on that jeep. :laughing:
