First I should give a little history on my Jeep.
It's a 2004 Jeep Wrangler TJ Rubicon. Currently sitting at 55,000 miles and sitting on a set of 35's
Current specs.
Rubicon express extreme duty 5.5" Long arm lift
Dana 44 axles with Alloy USA axles and 5:13 gears (stock lockers).
Custom weld on Beadlocks
TNT high line front fenders w/4" flares
TNT High line rear fenders w/4" flares
DOT light LED tail lights
High Beam Offraod LED headlights
Poison Spyder hood louvers
Poison Spyder fully welded Cage
Warn front and rear bumpers
Warn 9.5k winch with 10k synthetic rope
Body mounted swing away tire carrier
Smitybilt reclining racing seats with 4 point harness.
The plan
Stretch front and rear axle min of 8" each.
Dana 60 front w/Alloy shafts 5:38 gears and Ox Lockers. Trussed with the Artec Industries truss and Artecs full hydro mount. Artec's weld on steering knuckle
Ford 10.5 rear Alloy shafts, Artec truss 5:38 gears, Ox locker
Artec back half kit,
Fox 14" 2.5in air shocks
Swap out the TNT rear fenders for a set of Comp cut fenders.
Fuel cell to remove stock tank
Custom 17" weld on Beadlocks with 42 in meat.
Current specs.
The plan
