101 - 113 of 113 Posts
Slab King
I was psyched on the 4:1 first gear and reports of strength on the nv3550...
But honestly if/when this thing grenades and if I decide to stick with a 5 speed, I'll absolutely go back to an external slave AX-15 over another 3550.
The 3550 is nothing but headaches every summer trying to chase down grindy synchros. It just doesn't like the heat. And it comes and goes with no rhyme or reason. In the Summer, some days it's fine, some days the synchros are just gonna grind on every shift unless you're double clutching and giving a 5 count between gears.
Adjusting the clutch, swapping to different fluids, new synchros, always the same result.
Never had a single issue with the AX-15.
Just my personal experience. I really dig your build and looking forward to seeing the 5.2 swap unfold.
Discussion Starter #102
I preferred an AX15 over the 3550 but I feel like this was a good deal and it gets the ball rolling. Can always keep an eye out for one to replace the 3550.
What oils have you tried in yours? Just curious as I was thinking of getting some nice fluid to put in it (amsoil maybe?)
The 4 squirrels have never done me wrong and I may be a dumbass for taking out an engine that runs fine, but it's time for more HP. I really enjoy driving this thing on the street, but it's been getting more and more annoying. I don't love feeling like I'm wringing every last bit of power out of it all the time.
heheh. I hear ya. I was just talking with a friend about his Jeep (also a 4cyl) and how if I were to do it again I'd want a granny gear four-speed, doubler, some 4.88's, and .... yeah. There's a reason my YJ has a hopped up 302. :laughing:
Discussion Starter #104
I definitely should've finished the doubler I had all the parts for at one time. It would really help it offroad and I would be more hesitant to an engine swap.
I would also stick with 35s. I think the 37s are a big jump and most of the wheeling I do I could do with the smaller tire.
Slab King
I've run Amsoil, Royal Purple, Redline MTL, and Redline MT90. The Redline fluids are working best, Haven't noticed a difference in performance between the MTL, Which is 75w80, and the MT90, which is 75w90.
Discussion Starter #106
My wife rolled her eyes at our new yard art, but this thing was 2 miles down the road and $500.
Hoping I can off the 2wd auto to some mopar guy so he can have overdrive in his cruiser, but I don't know if people are into that.
Got it running last night. Fuel pump is bad, cut a hole in the bed and rigged up a spare inline pump and bam! Fired right up, idled well, and stayed cool at idle.
Talking to a guy on FB about a flipped D300 with all the goodies. Last steps are the bellhousing, motor/trans mount, and some rock auto parts.
Ax-15 can be converted to a ~5.15:1 1st year and a taller od also. They're the Lego trans of 5 spds.
Are parts still available? Last I checked it was extremely difficult to source parts.
That I couldn't tell you. The 1st gear is from a dyna truck only offered overseas AFAIK. Marlin Crawler would be the one I would contact on that. The 5th gear is from a Toyota supra, and shouldn't be too hard to find I would think.
Discussion Starter #111
This showed up end of last week. Was supposed to be fully upgraded with JB conversions LoMax 4:1 and a 32 spline front output. Turns out it has a later TeraFlex 4:1 low range set and a stock front output. The seller has offered to refund some of my purchase price to make it right, said he never actually took it apart to check that is just how he bought it.
Probably just going to stick with the stock front output? Not really sure. I got on the list for a TJ Rubicon case from SgtJeep so if one pops up I may just jump on it and sell this.
Its got some other issues, but that just comes with buying used stuff. Need to replace some bent mount studs, one of the shift pads is missing, shifters need some love, etc.
Hard parts from Rock Auto seem to be fine.
Electronics? Fuck that. I've had nothing but issues with the ones I've bought from there.
Discussion Starter #113
I buy everything on rock auto.
I try to get the more name brand parts, but for this build I'm planning on replacing the cooling system parts and probably do tune up stuff. Also need a flywheel and clutch kit.
Thankfully I've been working this last week through the shutdown, but not sure how long it'll last. I've kinda put a stop on jeep spending for the time being, for obvious reasons.
If I do get stuck at home I'll be working on those honey-do projects so when things start settling back to normal I can focus on engine swaps.
