181 - 197 of 197 Posts
Master of none.
Discussion Starter #182
For the dash to continue on in aluminum, it need mounting points, so a small flange was cut out, & fit to the dash bar, a-pillar, & door bars, just like the driver side, (obviously a little more practice on this one)
Then tacked in place,
Then the seat, shifter, & floor panels back to the rear steer pump were removed, & the dash was completely welded in,
And that's about all I got done in 4 days,
Next on the plan is finish the roof bars while the interior is out, then try to finish up this tin work so I can move the sheet metal brake out of the way. but that'll all have to wait until next week,
Dinkerdoodledoo
This area behind the driver seat will likely house the air compressor & solenoids for the diff lockers, the passenger side is undecided, but at least there is a little real estate to be had later.
What controls are you using for those? I have to control an Axletech 600 t-case too.
Dinkerdoodledoo
Master of none.
Discussion Starter #187
And today, May 20th 2020 I feel I may have wasted my time documenting anything on this forum, guess I'm not a fan of the change,
I suppose I will post this update & see how things go from here,
Continuing on the project I figured I would finish up the tube work in the roof while everything else was still removed from the cab,
3106313
3106314
Once fit & tacked into place, I went back to tin work, a little over a day & a half to finish up the forward foot areas, & outer firewall panels, so now the cab once again has a complete floor & firewall,
3106315
3106316
3106317
Since there was still pieces of aluminum laying around everywhere, I threw something together to finish out the dash panel,
3106318
After the chassis is powdercoated this panel & lower edge trim will rivet into the truck,
With all the dash pats in place I did a quick mock up to make sure everything was going to fit & clear,
So far so good,
3106319
3106320
3106321
3106322
I finished out the week with designing a passenger seat mount, which has been cut out & cleaned up, but pics can wait until I get the welding done & actually bolt the seat in, possible next week,
I'm really trying to get to the point I can close the doors & be done with the interior for a bit,
for some reason, this last update you put up has the images showing at a "proper" size and not the small thumbnail of the earlier ones. give it a week, all the reasons this is better than FB and IG are still valid 😆 none of the content is lost
if you do head somewhere else, drop a link in here though!
Master of none.
Discussion Starter #189
I had the option to thumbnail the images I put in this post,
the thumbnail pics must have been default for the change over.
I'm probably just being petty about change for no good reason, hell I wouldn't even use taptalk on my phone cause it "doesn't look like pirate"
I hated tapatalk and all the mobile versions, the dark mode of pirate (click the 3 dots in the upper right hand corner by your user icon) helps a bit.
apparently there are more changes getting rolled out over the next couple weeks to HOPEFULLY address the 20 posts per page and odd font sizes
Rock Stacker
You could recreate your build on pIRATE4x4.com in about 15 min. I already did mine. Then it will be safe and documented for yourself and others.
i really hope you continue to document and share. i would be pretty IRATE if i didnt get to see this build to its conclusion. Either way, keep up the great work, you sir are an artist.
Master of none.
Discussion Starter #194
Pretty busy week this time around, I started off with a quick trip over to CA & picked up what will likely be the next camper project,
3106753
That's two of these double drop trailers I have now, so I spent the better part of a day cleaning out a spot in the yard for it, I really need to get a few things out of here, (3 big trailers not counting the current crawler hauler & 2 Peterbilts definitely take up some room,
Anyway, once back in the normal groove at the shop, the passenger seat mount I started last week was finished, test fit, & kiddo approved, these will get powder coated, then riveted to the seat before mounting,
3106754
3106755
Then for some odd reason I decided to mount the front fenders, I have been putting this off for a while now, for a couple reasons, one was they would be in the way for other work anyway, & the other was I did not know how I wanted to cut the opening to have the right amount of clearance, & look right, (hard to beat the look of a late 70's ford factory body styling)
I was really hoping to make the cut it in one clean shot so the part I have left over would make a good template for next time I have to do this job,
Half a roll of painters tape later & I ended up with this,
3106756
Obviously at full bump,
In this pic you can see a small stand holding the front of the clip up under the grill,
3106757
It was clear more body mounts was next on the to-do list,
Master of none.
Discussion Starter #195
Odds being pretty high this thing will get wrecked, I am trying to simplify repairs as much as possible, So for body mounting at the front of the chassis I used a couple tube clamps that I had in the "goody stash" I believe they are used for mounting/moving ballast weight on circle track cars, but they are aluminum, so the caps were removed, & used to build a steel lower half that I could weld to the chassis,
3106758
Two of these clamps were built & after some careful measuring & placement, they were tacked to the front of the shock hoops,
The other aluminum half of those tube clamps were setup in the mill, drilled the threads out & counter sunk to basically become a second set of caps, A couple pieces of .75" aluminum bar was cut, & machined to both serve as the second part of the tube clamp, & bolt to the front fender using factory mounting holes,
3106759
3106760
3106761
3106762
in the second pic of this post you can see both the cap, & home made half of the clamps have drilled/tapped holes, There will be a smaller link/bar, that will go from the main chassis, to one of those two threaded holes for more support/adjustment,
Hopefully in the event of a crash, if all of the main bracketry survives, & one strait section of 1.5" DOM will be all that is needed to get sheet metal hung back on the frontend,
Later on I will probably do some other type of clamp off this same tube that will mount the front pins for the hood.
Since I no longer needed a stand to hold the front clip up, I got it out of the way, jacked the front tires up just off the ground & cycled the steering to see if there was going to be any contact, or if I was going to have to cut the grill, (I probably spend as much time during the original layout/planning stage figuring front axle placement, as I did anything else trying to avoid cutting the grill if at all possible)
3106764
If the truck ever sees any serious articulation there may be a little contact, but I think I can live with that,
On the other end the cab corner was already close, so I knew the fender would be too,
3106765
Turned at a full 42* these Axletechs look like something is broken on them,
3106766
Everything looks awesome at full bump, here it is roughly at ride height,
3106767
Master of none.
Discussion Starter #196
Since the front fender thing was reasonably successful, I figured I'd move right on to the next part I had been avoiding, & that was finishing out the back of the chassis, I wasn't sure what I wanted to do back there, I knew it would involve some pretty mundane machine work, but at least the list of requirements was short,
1, Continue the chassis to the length of the bed sides,
2, Tube inserts on the lower stringer tubes must be solid to block coolant flow
3, Proved enough room for rear sway bar mounting,
So a couple pieces of 2" cold roll were lopped off & run through the lathe, turning the OD down to fit inside the 2" x .120 lower chassis (stringer tube), these tubes will be used to carry coolant to & from the radiator & engine, so I couldn't just sleeve the tube splice by just using a smaller tube, the inserts have to stop coolant flow,
When machining these inserts just the ends were machined down, leaving about a .75" wide band/shoulder in the center, there a hole was drilled & tapped in each one, then one end was bored out to intersect this cross drilled hole,
During final assembly I will install bleeders in the threaded holes to bleed air out of the cooling system,
This is the insert slid into the lower chassis tube after machine work,
3106768
Peeking down the bore to the cross trilled bleeder hole,
3106769
Here you can see the other end of the solid insert was also bored out, obviously not the full depth, the bore stops about a 1/2 inch shy of the shoulder/bleeder hole,
The upper sleeves/inserts are just some heavy wall 1.75" tube machined down to fit inside the 2"x.188 upper chassis tubes, a small shoulder left to keep the from moving around, & lots of plug weld holes with a couple at each joint,
3106770
3106771
3106772
The 4 cross tubes should provide a good place to attache a solid tow point,
3106774
The next couple weeks will be busy prepping for Mountain Havoc, then making that trip, but if I don't tear up to much stuff there, I'll be right back on this, maybe even get a couple bed sides hung on it before the end of June.
