1 - 20 of 96 Posts
Formerly known as: Tacoma 3-link my way :mr-t:
Why not start a build thread on a Tuesday?
Specs:
-'96 x-cab 3rz/w59, 186K mi, buncha motor bolt-ons, (leaving as-is)
-Chevy leafs out back, single shackle conv., bilstein 5150's, relocated x-member, lunch box locker, removed LSBPV, 3.55's :barf:
-Clocked t-case, clocked x-member, twinstick, LCE short shifter
-Dual batteries and OBA 1/2 way complete :shaking:
Going in:
-Typ. D44 out of a GWaggy, (free, so I'm gonna use it until I make up my mind, which might be a while)
-pre '80 Saginaw box ported for hydro,
-XJ coils (thinking about ditching), 5100's
-2" x .25" square links, bushings on frame end, Ballistic joints on axle, links will all be pretty long @ 42" each.
Had leafs ready to go, but changed my mind at the last minute figuring that I wanted to be different for the sake of being different and go to a linked setup.
From this:
To this:
To this:
I've lurked on this board for a LONG time, finally got my red star when I was ready to get serious about my axle swap.
BTW: Constructive criticism is ALWAYS welcome. Seriously.
Cannibalized steering components:
Firewall plate is uglier than a mudfence but keeps the elements out.
Steering angles are fairly good:
Discussion Starter #5
Current issues:
- XJ springs were WAY cheap, so I bought them. Got them mounted up and starting to think that they are just too damn big. 24" free height and nearly 6" in diameter. These are fairly soft, but I'm still considering going with something like a Ballistic Fab/blue coil 18" tall 200-250 lbs spring as those are merely 3" in diameter.
- 4x 3/4" bolts through a 1/2" of A36 plate holds the x-member on right now, I should probably do the calcs (yes, I am a field engineer very slowly working on getting his P.E.), but I just don't think that it's quite enough. Comments, ideas, suggestions?
Discussion Starter #9
whered you get that sick girll!! that thing looks sweet!!! i want one for mine! :D
I made it with about $20 worth of bondo, fiberglass and metal mesh. It's a slightly different version of the "satoshi grill mod". There's a an old write-up on a toyota site somewhere. One of those arts and crafts projects that you can stave off boredom with during the winter.
did you make the adjustable coil buckets?? if so, youre a genious and should market them!!! if not, they are still cool and so is your truck:D
Sadly, I did not make them, Ballistic fab did. I may offer a kit for an :angry: version later though. Thanks for the complements, I gotta admit the Silver Bullet build thread (among others) was definetely an inspiration to get this thing going.
Ballistic used to sell those but I can't find them on their website anymore.
I know that your rig is leaf sprung, but just in case you change your mind:
http://www.ballisticfabrication.com/Adjustable-coil-buckets_p_32-1183.html
Current issues:
Ive always liked the idea of going with the smaller coils your mentioning. It should still do the same job, its smaller and should fit well. Its not to common.
Discussion Starter #11
Test fit the links, seeing if I need to clearance the driveshaft. Should be alright.
Finished the Driver's side frame plating (finally).
For this weekend:
-Finish mounting steering box and hook up plumbing lines. I need to plug the hydro-assist ports for the time being.
-Finish link ends and get axle located.
Discussion Starter #12 (Edited)
Cut off the end of the stock pressure line, bored out a -3AN fitting and welded it on. It doesn't leak but I'm still going to go back and braze it.
Hooked up the steering lines, filled the res and called it good.
Ballistic Fab shock towers didn't come with the bungs, and rather than spend $25+ shipping I decided to make my own from some 3/4" pipe and extra thick washers.
Had to trim the towers slightly to fit, in addition to massaging the inner fender to allow the bolt to clear. 12" travel 5100 from TimBhudda.
Couldn't contain myself, so I welded up a temp muffler and used my commuter Saturn to crank her over. Video here:http://s157.photobucket.com/albums/t69/Philfab/SAC/?action=view&current=PA100350.flv
Discussion Starter #14
You are running a Waggy axle? I'd love to do a setup very similar to yours once I can afford it :laughing:
Can't wait to see it on tires!
Aiyup, D44 out of an 88 Grand Wagoneer.
Painted up
Still on stilts :(
Exposed shock shaft. I need shorter, softer coils and 10" shocks. I figure I can swap out the 12's I have out back that are absolutely beat to shit for the one I have up front, and just buy some new 10's.
Discussion Starter #15
Oil pan kit shows up tommorow, and if my joints aren't shipped I am going to come un-fucking-glued (potential scathing review but I will give folks the benefit of the doubt).
Whats left...
Short term (This week):
- Install panhard after oil-pan is mounted
- Swap shocks for 10" travel units
- Swap springs for 18" x 175lbs ones
- Finish welding, grinding, painting, etc.
- Bleed brakes.
Long term:
- Gears and locker for the 44, (going with 4.88's and an Aussie)
- Re-gear rear-end (locker already installed, 4.88's sitting in the garage)
- Install double-ended hydro ram and cooler (lines are already made)
Really long term:
- Crawler
- 3-link rear
Discussion Starter #16 (Edited)
Look what showed up...
Just in time...
2-5/8" Ballistic joints, square tube inserts, poly bushings and jam nuts.
Little irked that they don't come with set screws or zerk fittings like they show in the ad. Oh well...
Slightly disappointed that the square tube insert isn't threaded all the way through, so the there's about 2" of stud still showing. That was clearly stated on the site though, so I can't really bitch, I mean, they build all kinds of other pimp shit, can a brother get another 1/4" of threads for his $17 + S&H?
I'm praying to every known deity for good weather tommorow, keep your fingers crossed, and we might just see Bumpy rolling.
ballistic is cool but good luck with those joints, every one ive seen personally run has ripped the stud off but they'll hook you up with a new one
Discussion Starter #18
I haven't read any bad reviews about them, but thanks for the heads up, do you have any pictures of a broken one?
I did notice that the welding is ever-so slightly undercut in a couple places, I should take them into work and let the Con-Am guy take a couple shots, he's got to be getting tired of x-raying concrete.
throw some numbers from this bad boy in the link calcualtion census thread!! undercut and lack of throat(enough filler) on those welds maybe? hard to tell, the whole thing could have been beveled and filled with weld and those could just be light cover passes to make it 'pretty'? i buy stuff from ballistic like every other week...they make cool shit! i actually wish they would expand theyre product line so i could just shop there for everything...
Discussion Starter #20
Easiest part of the build::laughing:
Nothing fancy here:
It's not quite ready to roll, but oh, what a feeling:
I did manage to get the flex joint stuck in the last tube adapter I welded up, made the vast assumption since the other ones didn't need the threads chased, and I was a bit excited to get the thing together. Fought with it for about 10 minutes and realize I should've been a bit more patient. Oh well, worst case is that I'm out $20. Lesson learned.
1 - 20 of 96 Posts
