1 - 20 of 220 Posts
hey guys i thought that i would start a post on my build and yes it is a one ton tj.... :grinpimp: if it not hard core please move for me or let me know.
here is the low down on the before
04tj
4.0l
aw4
d300 with low max 4to 1
Chevy d44 frt. and 9" rear
37"
100 wb
suspension seats
and on tho the now
same motor and trans
d300 with the low max 4 to 1
32 spline outs frt. and rear
14 bolt rear spool
chevy D60 spool
5.13
sway-a-way coil overs frt. 2.0 12" 200/250 springs
sway-a-air shocks rear 2.0 14"
dove tail the rear 11"
boat sides
low COG frame height of 22"
frame back half
42iroks on h2s for now bead locks will come later on
cambell hood
and so on .......
here are the pics of what i have been working on this is very low budget build so thing may change as i go if good deals come around.
5.5" missing and put back to gather
the inner fender made out of 18g getting fitted
both sides welded in
back half tacked in place
here is a shoot of the dovetail tire
Discussion Starter #2
rear truss made - not done!
suspension tack in place order some new upper mount for the frame to make it adjustble on the anit-squat from 76-94-110%
full stuff 4" of up travel
and with the tire at stuff
start of boat side
Discussion Starter #3
hood pics :smokin:
rear disk brake parts and longer wheel studs for the 14 bolt
thats it for now!
Great start. Something about the line on your comp cuts look crooked. Maybe its just me. Can't wait to see the rest.
Discussion Starter #6
Looking good! Couldn't resist this board either...:D
nope lol :D
thanks, i think its just where ever thing has been patched back to gather and the difference in the paint maybe.....? i do still have some clean up to do but but not much.
Wb?
Did you forfeit any seat room in the back with the dovetail? It doesn't look like you did at all. Interesting to see it all.
Why'd you scab the links that way? Plans to redo them?
Discussion Starter #10
Wb?
shooting for 109 maybe 110 for the wb. as for the rear space i did not lose any floor space still can use a stock tail gate and/or if i wanted to put a seat/s back there i can. sorry for the pics only showing half of it but my 2 car bay garage is not very deep so its hard to get a full back view of the jeep... ill get a better pic when i get the jeep rolling around. as for the arms i am redoing them they are just for mackup
Discussion Starter #11
did some work yesterday....
made my new up frame side link mounts
got the rear disk brakes mounted
and set the rear end down on the bumps stops just to see how low it really is
it is only 45" to where the body roll in just below the soft top rail at full bump in the rear :eek::eek::eek:
we did strip and start cleaning up the frt. 60 but forgot to get a pic of that more later this week
Discussion Starter #13
sweet looking build. thought i would never go tons. now everytime i see a new build thread i think i get a little closer to making the leap.
thanks for the nice words ! i never thought i would too but thanks to pirate i now have one tons :grinpimp:
Discussion Starter #14
small up date...
well with a small bump in the road its starting to look like i will get to order all the parts that are need to get this bitch done...
things that are still needed
chevy 60
spool, gears, and install kit for the 60
steering still looking at full hydro just not sure witch one...
cage going to order 1.75 by .120 wall dom
all the parts for the brakes- hose, fittings, a one handle cutting brake
install kit for the 14 bolt
fuel cell and all the stuff for that
and the little odds and ends
its a long shot but it may make it to EJS but we will see
only pic i have got from this weekend of work...
made the rear adjustable bump stops for the rear kind stuck at this point until i get my 60 or get the cage made more will come as parts roll in..
Looking good, keep it going. Have fun cleaning up that dana 60, little wire wheel action should be sufficient..
Discussion Starter #17
thanks man, that the one thing i really dont like doing but it has to be done.
well the list of part to order is getting
pick up all the dom for the cage, ford traus fan over the weekend
the fuel cell and fuel ring, the springs for the coil overs new tubing adapters, should all be here this week
going to start working on the boat sides tomorrow night :smokin:
Discussion Starter #18
started working on the rt side boat side last night what a pita
pics
Discussion Starter #20 (Edited)
updated
got a lot done in the few hrs that we spent on the jeep. got the rt side boat side tack up, cut up the exhaust to replace the cats ;), and gutted the d60.
full hydro has been order and all the stuff for the d60 has been order.. thats should do it for all the parts now its time to get this bitch moving...:cool:
1 - 20 of 220 Posts
