1 - 18 of 18 Posts
I am needing to know if a impco ca125 mixer/carb will be big enough for a 80.8 CID 1.3Liter 4cyl suzuki samurai motor . It says it's good for 202 cfm and I figured 129cfm on the samurai stock motor if I figured right but if I rebuild it .30 over and high performance head will it still work ? Should I just go with a 225 mixer to be safe ?
Banned
If you have not bought anything yet go with the 225 to be safe.I don't think the 125 will be big enough honestly.I have not dlet with anything that small though but my friend is forklift mechanic and he say's even the larger forklifts that have the 4 cyl's in them use the 225.I have seen a couple of small forklifts use the 125 though.
Hey Ripper,
Do you know where I can get a 22R Carb throttle plate adapter to a Impco 225 mixer locally? That is all I need to compete my propane conversion.
Dazz said:
Hey Ripper,
Call Larry Alan at Propane Systems of Texas, he would know where to get one. He is the one that got my all of my adapters.
number is 817-831-6139
Banned
This si the same man I use also.If you need any help just PM me maybe I can give you a hand.
Some claim better, some say the same.... I don't know if anyone has any real comparisons. I am more than pleased with my switch to the pane. I wouldn't go back to anything else.
while we're on the subject-
How good does it work with slightly lumpy aftermarket cams? I have no spec on my cam because the PO built the motor, but it doesnt have great vacuum and the idle has a little bit of a bump to it. Am i gonna have issues with the mixer and a lower vacuum signal? From what i remember, im around 13-15"Hg in park at 1000rpms.....
Banned
Not qiute sure on that but I will go by and ask Larry tomarrow when I am in that area if I have time.I have a rough idle on mine and it seems fine with no issues.My other buddies jeep also has a healthy motor and a pretty big cam in there and he has no problem.s ethier.I do know the vacum of the motor is basicly what pulls the propane into the engine.
You'll be fine. I run an RV cam in my 360, bored out .030 over.
Your only concern about vacuum is making sure that you have a good vapor hose and do your best to keep it under 18 inches or so.
BTW, I have about $325 into my propane stuff, $400 with my extra forklift tank.
Banned
Rv cam aint shit... :flipoff2: ..lol..Yeah the prices I gave were new with Larry he did not have any used stuff when I went and I did not want to wait...and how many months has my shit been apart.. :shaking: ..I should have waited a week and got a deal like you bro.
I peak at 2400 RPM :D
It pays to be patient..... :smokin:
:flipoff2:
1 - 18 of 18 Posts
