1 - 20 of 29 Posts
I'm having Sunray build me one of their 1550 front-ends, I need a HP center section.What are the pros & cons of Dynatracs Prorock60 and Teras 60r(The CRD is out because it is a shovel up front)
Haven't I seen this thread before?
I don't think the CRD will be a shovel up front. Since it will not be rotated up, it should slide over the rocks better since the leading edge is higher, it would be more like a ramp, not a shovel.
However, I think I agree with Xtreme and would say the ProRock would have higher clearance in the front. Maybe do the CRD in the back for triangulation. It will depend some on what type of suspension you are running.
Why aren't you using a 9" center section? Even more ground clearance then the two aforementioned center sections, pinion bearings are stronger, pinion gear is stronger, more gear ratio selections, and they can build you a trick chro-mo center section that is very strong.:confused:
since you brought it up.....i vote for mog9's:D .
I don't know about the tera unit, but the pro rock has a seperate custom oiler for the pinion, which I like, and I think Dynatrac makes top notch stuff. If I had the cash, Id buy PRO ROCK. Ive helped with the install of a pro rock, and it is one NICE axle.
Scott
Discussion Starter · #11 ·
I'm not using a 9" center because I prefer a high pinion. I drive like shit and can't keep a low hanging driveline off of the rocks. Th anks for the input.
The ProRock has two oil sumps, which is a huge advantage for jeeps driven on the road alot. It also has more clearance and is a much stronger housing.
The ProRocks also have an optional bridge for mounting links over the pumpkin, the bridge bolts in so you could make one yourself, or when you switch suspensions buy a new one from Dynatrac to start with a clean plate.
I went with Tera when I did my axles near the beginning of last year. I did have some lube problems in the rear even though I was running a pretty conservative anlge (i.e. less than 10 degrees). Depsite what I've heard, Tera's customer service was excellent. They responded very quickly to my problems and sent out replacement parts immediately.
That being said, I would choose the ProRocks if I did it all over again :flipoff2:
XtremeEngineering said:
And not 1/4 as strong as a ProRock high pinion:rolleyes:
I would like to see the math to support your claim. Not trying to be an ass, but I don't see why it would only be ~25% as strong. What aspect of the high pinion 9" carrier makes it that much weaker than a D60? :confused:
· Moderating Midget
You may want to have Sunray build it with a reagular HP D60 center and shave it themselves in-house. They built my RCD60 and shaved it and did a GREAT job.
If that is not an option, I would do the Tera. The Dynatrac is a HEAVY pig.
1 - 20 of 29 Posts
