Which is better? PSC performance power steering pump kit or hydroboost conversion? I know hydroboost improves braking, but does it improve steering? Is it worth the swap? Thanks, Bradley
this is a pretty straight forward easily looked up question
hydroboost eleminates a vacuum brake booster and replaces it with a power steering run hydrolic booster if anything it will make you steering worse under hard breaking while turning if you are looking to improve your steering try hydro assist with a pcs pump or just drill out the orifice on the back of your pump to try and get more flow
Hey Third - hydro conversion is purely for brakes.
However, if you're upgrading your PS steering pump and box in the process, I would imagine you would see an improvement in steering for big tires.
The upgrade GM PS pump for hydro is good for x3 full stops if your engine dies (safety feaure). I don't think hard breaking is going to affect your steering ability...
1 - 4 of 4 Posts
