1 - 4 of 4 Posts
do most PTOs that bolt on a manual tranny (or transfercase) have the same bolt pattern?
I found a few at the wreckers so I was thinking that If I use one of thows I can use my continus run air compressor for an OBA setup
Yes, they have a few different series of PTO's, and those use the same bolt patterns,"BUT" you must be certain that you get the right gear (driven gear) for your unit. check out a Chelsea web site or contact a big rig truck parts place for the specific gear you'll need. I got a PTO for my SM 465 for free, but I needed the correct gear, which was like 58$.... The PTO's are pretty much "Modular" as they can be swapped end for end for right or left side mounting, and the gears I am yammering about come out really easy. Then again, you just might get the right one the 1st time at the boneyard;) Good luck!
Whats the website?
1 - 4 of 4 Posts
