1 - 13 of 13 Posts
I gotta do this tonight. Figured I'd ask before I try it. What's the easiest way to get it out of the pitman arm?
if a pickle fork is the proper tool, it wouldnt ruin the boot.
Use the *real* proper tool, a TRE puller.
Wont ruin anything, and takes maybe 10 seconds.
yeah, what he said.
Discussion Starter #7
Sorry, I should have been more clear. I am pulling the TRE-like thing out of an IFS pitman arm so I can weld in an insert and use a chevy TRE. I am thinking a press would be the best but I don't have one so I guess I will be running to a friend's house if I can't hammer it out.
so you want to remove the stock "insert/ball" in the pitman?
remove the back of it, and smack it w/ a BFH. Drops right out.
Discussion Starter #10
Yep, hopefully its that easy.
Vendor
Grind the lip of the top sheetmetal cap. You can see where it is formed around to capture the top cap. Its thin, so wont take much. Once its ground through, pull all the junk out with a screwdriver. Clean up the pitman, and press in the insert.
This little ol' Snap-On tool is what I use. It works really well. I just take the castle nut off, turn it over and thread it back on until the end of the nut is almost even with the end of the threads so as not t' damage the threads...
Discussion Starter #13
Turns out I have an aftermarket pitman arm so the insert doesn't fit!!
1 - 13 of 13 Posts
