1 - 3 of 3 Posts
Some damn fool PO evidently had a very good underliner sprayed on my 71 40 and now thet I'm getting ready to pull the tub off of the frame I can pull the stuff off and all I find is the factory metal with some overspray of the original color. The only rust that I have found is under the back doors. Any tips on pulling the tub?
On the rear under the doors, I had to drill a hole on the bottom channel to put a 3/8 extension bar through the bottom. I couldn't get the bolts out with a wrench. Put the socket on the bolt, the extension through the hole onto the socket. Made a hard job easy.
1 - 3 of 3 Posts
