1 - 4 of 4 Posts
Pully Boly Situation?
Ok. My crank pulley bolt ('85 4runner) is pretty much stripped out completely. I've many different methods and nothing seems to be working. I'm pretty sure that when the bolt was put back in last time, the threads got messed up and now they're fused together. My next attempt will be using a grider to resize the socket. Has someone else has had this extreme situation? What did you do/use to make it work? All info appreciated.
I'm gonna try welding it if i can't get if off after grinding it. Thanks for the advice.
Weld it , i had to do it on my 20r , the heat alone is enough to break it free :p
1 - 4 of 4 Posts
