1 - 3 of 3 Posts
Paul,
Would you believe that I'm still having problems with my frikken powersteering box.
Replaced the seal - but was still leaking like a seive....Pulled it apart again - this time removing the shaft completely.....
Just wondering how "shiny" & smooth your shaft was where the seal was.....mine has two shallow gouges & what looks like a burnt rubber that rings about the shaft <IMG SRC="smilies/crybaby2.gif" border="0"> .....Sound like yours?
Just hoping the shaft isn't stuffed....
Any thoughts? Thanks Mate....
David - yes... I had/have those 'burnt' spots too. I gave it a quick scrub with some fine steel wool and put it back together. The seal is fine, but the top bolts now keep loosening up. <IMG SRC="smilies/mad.gif" border="0">
I've got a steering box on the way to TheLakeRat right now for a rebuild and ports for a ram. When it's back I'll be able to play with the one currently installed.
Good luck.
Paul
Thanks mate!!
I've started cleaning mine - but I'm a tad concerned about the actual gouges....
I'm probably going to finish cleaning it up & refit the sucker & then just start looking more seriously) for an alternative to swap in..
Chrysler Australia have said that they'll only sell basically the entire box not...for $1400aussie ($730greens)...not an option I'm keen on....
Well tonight seal number 2 goes on <IMG SRC="smilies/jeep1.gif" border="0"> ...
1 - 3 of 3 Posts
