The artical states.
11) Ford knuckles have a shorter steering arm than the Chevy/Dodge. A 1.5" diameter tie-rod on a stock Ford D60 will just touch the diff cover at full lock. The same tie-rod on a GM Dana 60 would be just over 1/2" away from the cover at full lock.
So if I use a tie rod on top of the knuckle will it give me more room because the diff cover is sloping back at that position? I want to use 3/4 heims and as thick as a rod as possible but I dont want to be macking the diff cover either. As far as stress goes on the rod I have 42's and will be going full hydro most likely so it needs to be as strong as reasonably possible. I was looking through some sites and I can get weld in bungs to fit a 1" I.D. tube but that only leaves me with a .25 wall tie rod and Im thinking something bigger would be better, or something sleaved over the smaller tube. Its a 93 ford dana 60 if it matters
Thanks
Mike
Thanks
Mike
