1 - 7 of 7 Posts
trying to figure out which arm is right and which is left. on the shock mounts on the arms one tab is a little long on one side. does the long side go on the outside or inside?
also which way to the bottom coil buckets go, does the opening go to the outside or inside.
thanks
jeff
I did not know Ford made arm's that were different. I don't have a clue what you are working on but the EB's and the early trucks that I have delt with all of the arm's are the same.
The only diffrence left/right I have seen, is the shock mounts. And this is only on some trucks. Some trucks have the shock mounts both on the arm, behind the c-bushings. Others have one in front, one in back. Then others have quad shocks, one front and back on both arms. Of course the other diffrences have been mentioned, bolt spaceing on top. Also maybe an EB fullsize thing or new/old thing, there are two diffrent length bolts that hold them together.
1 - 7 of 7 Posts
