1 - 16 of 16 Posts
ok i have a class 1 comp jeep setup for rcrocs it has a hp30 with 27sp rcv's 4.88 an a lockright along with wj knuckles an brakes the tires are 33x10.00x16 km2s filled 3/4 with water my question is will the rcv shafts hold up? or should i just put these in my daily driver an upgrade to the 30sp?
Vendor
I have seen them out live the R&P
I have a tj rubi with them in the front that i run 37" reds on there. Ill crawl a rock where it picks up the whole front end with one tire amd they are fine. Only time ill back off is if they start hopping bad.
no they dont make a sticky that small but im running a super narrow tire 33x10.00x16 km2 for more pressure on the rock/crete an to slip threw gates an big bolders easier
I've done plenty of bad things with my locked D30 on 35's. Had a front tire bound up in an undercut and still powered through it and climbed up. All sorts of full throttle spinning turning lock to lock.
Only issue I ever had was when I had a unit bearing going bad. It was loose enough to cause the orange boot to hit the 3 bearing bolts and tear up the edge. No damage to the joint, just replaced the boot.
1 - 16 of 16 Posts
