1 - 3 of 3 Posts
I have six of these , all new... five haven't been out of the RE boxes.
$320 to your door in the continental US.
This flex ball joint is designed for use in wishbone (Tri-link) suspension systems. Typically this joint is welded to the control arms, then bolted to a bracket on the top of the axle housing. This version uses a 3/4" bolt to secure it to the housing. The joint will rotate up to 30 degrees. This joint could also be used in an extreme duty lower control arm application.
The joint measures 2 7/8" in diameter and 2 5/8" wide across the misalignment spacers.
Joint includes the cup, two races, the ball, a preload adjuster, and high misaligment spacers.
1 - 3 of 3 Posts
