Having trouble with the emergency and rear brake application. I adjust the drums manually and things work great for a day or two, then play builds up again, and the emergency brake quits working and it feels like the rear brakes aren't applying at the same rate they do when it is adjusted properly and all the braking is being handled by the front brakes. Can somebody tell me what's happening and how to fix it? Thanks, Danny
btw, drums and shoes are fairly fresh
added later----ok, I can't get the adjust to work with the arm connected to the cable, I have to pop off the small rubber cover (below it) that allows you to adjust it with a screw driver.....the arms do not click and activate the adjuster.......
