1 - 11 of 11 Posts
I have a fairly stock sammy with heavy duty shackels. But they let me run 31X10.5 without problems. At about 60MPH a shudder develops that feels like it is coming from the rear drive line or the propeller shaft. The U-joints are all in good repair and do not bind. Should I try wedges or having the shafts balanced?????? <IMG SRC="smilies/question.gif" border="0">
I would try the wedges first. If the vibes settle down your good to go. If not check the tranny and T-case mounts, a small twist in the t-case mounts can cause a vibe. I had to go to a CV drive shaft to cancel out the vibration I had after doing my spring over. <IMG SRC="smilies/biggrin.gif" border="0">
You do not need shims with your shackle lift! Look elsewhere for your vibe. Did you take off the 2 Driveshafts and check for binding? Do not rely on checking them in the rig take them off! Check motor mounts,t-case mounts and tranny mount. Wash all crud from d-shaft and check your weights.
Peace,
Chance.
Ujoint problems usually occr at lower speeds and are noticable under load and decel.That speed would appear to be a tire balance issue.Just to ensure that you checked your driveshafts are in phase right?
I have new einge and t-case mounts. U-joints have been inspected off the vehicle. The shackles are 2 in. When I first had the viberation I have all my tires checked for bent rims and out of balance. I found one bent tim and replaced it. Vibeation is still there. One more twist. With a tail wind the viberation sometimes does not occure at all. With a hard side wind or head wind the viberation always happens and bad. Torque also seem to affect when and how bad??????? <IMG SRC="smilies/confused.gif" border="0">
You didn't actually say it, but was the truck vibration-free before you added the shackles? Have you swapped them back off to see if the problem goes away?
I would still rotate the tires & see if there is a change in the situation - it's good exercise & free <IMG SRC="smilies/biggrin.gif" border="0">
You also could set the rear of the truck on jack stands so the rear end is hanging loose- try to move it side-to-side & look for problems.
Did you check out the pinion nut?
[ 09-28-2001: Message edited by: 0ILBURNER ]
Discussion Starter · #11 ·
Thanks for the ideas <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> The truck came with the heavy duty shackles. I have have the vibebration since I have owned the truck. I have had one broken engine mount t-case mount and one bent rim. I have replaced all of them. I have inspected the the axle bearings and the pinion bearing when I put in my locker. The only thing I can't check is the preload on the pinion. Keep the ideas coming. thanks <IMG SRC="smilies/smile.gif" border="0"> <IMG SRC="smilies/wink.gif" border="0">
1 - 11 of 11 Posts
