I could do that...and still have bolt on brackets. The top mount will be parallel to the springs. I will probably give this a whirl and see how it works out.Weezer said:looks nice and clean but I like to mount my shocks paralel to the spring, this pic should explain it better, I think the shock gets better movement this way
I'll be up for a short weekend around Feb 14th. I'll PM details once I've got stuff figured out.ToyToddy said:Looks fine to me. If that is what you came up with musta had a reason to mount them that way so go with it. Buy the way when ya coming up? Hollar at me an we will go have a few cold ones.
Todd
I hear what you are saying but its not any different the regular axle mounted shocks in the rear. In any case, it wouldn't take all of an hour to make a second set of mounts with tabs instead of the pin.Eskimo said:I'd say that wold be ok for an app where the whole axle will move up and down, but in rockcrawling, as the axle twists, the bushings won't be happy... and may even limit you at some point.
