1 - 1 of 1 Posts
I have a Haldex 12v pump that controls my rear steer. The problem is when I get on steep angles it dumps all the fluid out of the fill plug/vent. So I took the fill plug off and put a fitting with a rollover valve (some tube with a loop in it), and that didn't work. Then I added about 3ft of rubber line and an oil separator on top of the rollover valve and it still pukes ALL the fluid out on steep angles. The only thing I can think of is pluging the vent off or finding some sort of check valve. It seems the return side of the pump has some pressure because it will spit out all 3 quarts in a hurry.
I'm also going to call Haldex and see what they say, but I figured sombody on here has had a similar problem.
1 - 1 of 1 Posts
