Here's the deal:
Late 80's (IFS) GMC 1500 4x4, that's used mostly for farm duties and light wheeling (not a daily driver). The other day, the rear end went. It looks like part of the left bearing (closer to the short side of the carrier) broke in half and spit itself out (breaking off a couple of teeth off the pinion and the ring)
So, I have a few Qs:
It's a 6 lug (4wd) 10 bolt, 8.5 in gear. We can't seem to find another 10 bolt (6 lug)for a reasonable price. Will a 5 lug (2wd) housing and the carrier work? Will it accept 6 lug outers? If not, will just a 2wd carrier and outers work in a 4wd housing?
Axle will be out of the truck anyway, we'll try to rebuild it (first time for everything) and if that don't work out, then will just put in a used 6 lug 10 bolt (when it becomes available)
Also, in regards to shims. How many are there? One for the pinion (to control how far out it sticks) and two for the carrier (to locate it horizontally in the pumpkin?)
Thanks
Thanks
