How hard is rebuilding a 22re engine for a 88 toyota p\u? What is involved and what tools are required?
The engine has about 180k miles on it.
Run it until it spins a bearing, used to much oil, blows a headgasket. If it ain't broke....3Wheel_Drive said:So after how many miles should you rebuild it if it is still running ok?
How many miles? It's easy to hone the cylinders, put in rings and rod bearings, and a timing set, all with the block still in the vehicle.Mattb said:I am in the same boat and considering the same question. My rings are pretty much shot (blowby out the filler cap is ridiculous, and the oil gets black in about 750 miles after an oil change) and I have wicked timing chain noise (time for a replacement). A buddy of mine is of the opinion it may be both cheaper and faster to buy and install a rebuilt motor instead of replacing the timing chain and doing the machining work. My sense is he is right. Any input?
Can't link a pic from your hard drive. I can post it for ya thoughron thomas said:
Every 100k (or less) do the timming chain3Wheel_Drive said:So after how many miles should you rebuild it if it is still running ok?
