I have used Mobil 1 motor oil for several years in my vehicles. I have run Mobil 1 oil from day one in my TJ and also run it in both diffs. The front has a Tru Trac and the rear has a full Detroit. The time to change all the fluids is approaching and I need some input from the group. I plan on changing both diffs, the 5sp tranny and the transfer case as well as the motor oil. Should I stick with Mobil 1 or switch to one of these products. I have read good things about Redline motor oil and their shock proof gear lube but don't know anybody who uses Red Line products. Are they good and do they work? Can their products be safely used in a 2000 TJ, 6cyl, 5sp? I have also heard and read the claims of Amsoil but don't know much about their products either.
I also have two daily drivers that I would switch over to one of these oils if the benefits were/are real. One of those daily drivers has over 103,800 on the clock and it has only ever had Mobil 1 in the crankcase. Any input from the group would be great.
Thx
Thx
