I searched around a bit with no luck, also called around to some stores, still no luck. I am trying to figure out what redline product is best for, transmission, transfercase, diffs, and engine. Here is what i have, what is everyone else using and does this look correct? Amounts look correct? Tried to find toyota specifications but could not find anything on the amounts except for other vehicle models. anyone have any links for toyota specs? was going to buy a manual but do not really feel like dishing out $120.
for 88 4runner v6, 5sp, dual cases, 85 front axle
Transmission: RED LINE 75W90NS GEAR OIL - 3qts
Transfer case: RED LINE 75W90NS GEAR OIL - 3qts (dual case)
Diffs: RED LINE 75W90 GEAR OIL - 3qts (front & rear)
Engine: RED LINE 10W40 MOTOR OIL - 6qts
Links to the 2 gear oil types, one has friction modifiers the other does not.
http://pitstopusa.com/detail.aspx?ID=5644
http://pitstopusa.com/detail.aspx?ID=5640
Thx,
Brian
Thx,
Brian
