1 - 17 of 17 Posts
Okay, maybe this is a question for D-Web, but today, I ain't got tha time...
Am I in deep crap driving without the cross-member temporarily (the one behind the engine, in front of the t-case)?
Here's the deal...replacing the exhaust on the '83. Since I have the newer fuel injection, I purchased a used Y-pipe from a '94 so the O2 sensors would jive. Installed the Y-pipe and new manifolds just fine...but later realized it is from a LWB :mad: (fricken' E-Bay :mad:).
Well, the cross-member will not fit in the same spot due to the position of the cats and the y-pipe. I will likely reposition it in due time, but now is not that time (I now need to have a muffler shop weld up a straight-pipe 10 inches shorter than the muffler to replace the muffler and install the rest of the exhaust :mad:).
Anyway...fun as usual.
all is not lost young Jedi.
You don't need to worry about your truck falling apart w/out that cross member.
Depending on the condition of the Cats, you may have an eager buyer right here in Vega$$$$$. (me)
Gimme a call.
Gimme a call.
hey mike i may have a set of practically brand new (maybe 5000mi) cats for a 3.5RR for sale if youre interested, or if lucas doesnt want to part with his.
Discussion Starter · #10 ·
Well, here's the update. I went to a custom muffler shop and they cut the flange off my muffler and welded it onto a standard 'turbo' muffler, which provided the ~8" reduction in length of the exhaust. All's well.
Now if anybody is up for the y-pipe trading, they have to pay to have the flange welded back on the original muffler (and Mike has do all the labor 'cuz I'm in no way interested in getting back underneath my truck for at least 6 months...) :D
Don't know how far off you are from the x-member fitting...but the newer Rangies (89 and up maybe?) came with a different/smaller x-member due to the downpipes.
This is a common problem when putting aftermarket downpipes on an 87 or 88.
Anyway...you might be able to find a 89 and up x-member for cheap if it gives you enough room...
Dave
Ahem - ahhh - yes well..... I didn't even know there was supposed to be a crossmember there until I crawled under someone elses truck and went hey you got a custom crossmember??? :emb2: :shaking:
I did notice the brackets in case you were wondering.... total effin newbie:D
Anyway - haven't had one for 2.5 years - there always seems to be a much more interestin bit to put on that a boring ol crossmember.
So you should be ok.
I AM GOING TO PUT ONE ON SOON.... right after I have upgraded the front diff and chopped the back....:D
I actually preffer to call mine a tranny slilder as it saved my tranny from a direct hit from a tree stump...
Broke the rear steering rod in half and landed on the cross member which bent and got a huge dent in it...
Remember to check those mudholes for stumps :eek:
Dave
Discussion Starter · #16 ·
I got Mike's off his '90 in the back of my truck...it ran me about $2000. Mike said the dealer charges about $4000 and I was getting a steal. He said not to bother with the local pick'n pull 'cuz they charge at least that much plus the labor to go pull it (like another $2000). Overall, it was a good day, we got to use his winch, and I'm just so stoked to find deals like this in Vegas. :D
I totally rule.
1 - 17 of 17 Posts
