1 - 15 of 15 Posts
OK
I purchased a nice rust free Sammi last night to puddle around in.
I may even drive it to work and use as a light wheeler.
Im gonna swap in some toy axles ASAP . I first however want to get the thing a little more horses and clean it out .
I have a built 88 sammi but its got a 22re in it.
what all should I do to this thing to clean up the engine compartment???
What needs to remain hooked up on this carb???
Any cheap carbs that will bolt up to this thing besides buying a weber?
I think I heard somewhere about a ford courier carb working.
What's wrong with the carb you've got?
Clean it, rebuild it - don't change it.
Everything under my hood is stock configuration.
Runs great - even runs on it's side.
Unless you're going to do a engine swap, tune it up and drive it.
A quick fix to let it breath better is put a 2-inch exhaust on it.
OK I started removing all the hoses and electrical doodads from the sammi carb and it starts and runs fine but it wont idle after a bit and will die.
It will continue to run if I keep the rpms up.
I unhooked the computer and also made a new air filter setup from a piece of tobe and a cone shaped air filter.
Anyway to hook up a manual choke on this carb???
comon guys
did i screw up removing all the extra stuff besides the fuel line in and the stuff hooked to choke?
mine won't run for crap with all of that SHIAT removed, go over to the local zuk dealer and ask them to look at the factory manual, they'll print off all the diagrams for the hoses and electrics for you, and you'll be surprised how great that thing will run on angles.... Ditching all that stuff would be great in theory, but i tried and it just wasn't so.... I may be able to get you all those diagrams if you need... Hugh
well it runs good going down the rOAD. MORE POWER BUT IT WONT iDLE.
I tried hooking all the electric junk back up and was successful but it still wont Idle.
Guess Ill have to start hooking up th rest of the vacuum lines that I cut and plugged. :confused:
Discussion Starter · #10 ·
price $$$$ on pony in american pasoes.
Lemme know
I think I may have figured something out . :)
I sent you an email.:D
Discussion Starter · #12 ·
thanks
I heard that a carb from a 70s ford courier pickup wouild work on these as a direct bolt up.
Anyone know about this???
Discussion Starter · #13 ·
Heres a pic of the cute lil thing ,lift shackles :eek: and all
Discussion Starter · #15 ·
I found a weber cheap and Im going to try running it for simplicities sake.
Im going to extend the vents and also put some fuel cell foam in the bowl and also mount it backwards.
Anyone know where there is a good writup on these mods???
1 - 15 of 15 Posts
