1 - 6 of 6 Posts
I have a 1984 chevy blazer. im installing a superlift 6" lift kit. I have to remove te steering arm in order to install the new one that came with the kit. But the steering arm won't budge... i have tried everything and it won't move at all... can someone plz help me out .....thanxs
Beat it like it oooo's ya money
Torch, probably not the best idea unless it's very very stuck, but try this method first...
1- Spray PB Blaster down on the studs, up from underneath the arm into the crack between it and the knuckle, let it set maybe even tap on the arm a bit.
2-Bang on the front of the arm (If you're looking at it from the top and it looks like a "U" or a "V"...the point or middle of the "U") with a 5 lb hammer, you'll probably have to beat it for 2 or 3 minutes straight.
3-the conical spacers around the studs should have started backing out by this point...you can get a chisel, or screw driver on them and "back them out" (even though they're not threaded, this works).
4-Work the arm back and forth and it's off.
By the way, I tried to get one off about 2 weeks ago and banged on it for about 2 hours and got nothing...I tried this method and it was off in a matter of 5 or 10 minutes at the most.
-Chad
When I did mine, I beat on that crap for two days till it came off. One of those swedges on the stud that would not come out. Persistance is the key.
1 - 6 of 6 Posts
